marksb
Dec 11, 2011Aspirant
WD20EARS-00MVWB0 Westerd Digital Cavier Green 2TB
Hi, I just got a Duo V2 and a Western Digital drive. I didn't realize there were two different versions (wished I came here first). The drive worked fine so I ordered another one, not sure what ver...
marksb
Dec 15, 2011Aspirant
Update.
After sending my logs to tech support they couldn't find the problem so they wanted me to take the drive out, reformat it and put it back in. I just received my second drive which is the same as the first one. I hooked it up to my pc, formatted it, ran data lifeguard diagnostics on it and installed it in the Duo. Same error. I went ahead and put the original drive back in and it is now synching with the new one.
