marksb
Dec 11, 2011Aspirant
WD20EARS-00MVWB0 Westerd Digital Cavier Green 2TB
Hi, I just got a Duo V2 and a Western Digital drive. I didn't realize there were two different versions (wished I came here first). The drive worked fine so I ordered another one, not sure what ver...
PapaBear1
Dec 27, 2011Apprentice
That is one thing that is good about the direct connection, it will eliminate or confirm the NAS is the culprit.
What you are calling a "hub" is probably what the industry calls a "switch". A switch is a wired only device, and is always powered. The smallest is usually a 5 port, and you connect one port to either the router or another switch, and the other ports are then connected to other wired network devices. In my case, one port is connected to the router, and the other ports are connected to two desktops and three ReadyNAS units, leaving two ports open. If you are still direct connected and thus have static IP addresses set on both the Duo and the PC, try again inserting the switch between the two and see what the reaction is. I am just curious if it was the switch or the router.
