marksb
Dec 11, 2011Aspirant
WD20EARS-00MVWB0 Westerd Digital Cavier Green 2TB
Hi, I just got a Duo V2 and a Western Digital drive. I didn't realize there were two different versions (wished I came here first). The drive worked fine so I ordered another one, not sure what ver...
marksb
Dec 28, 2011Aspirant
I can't find the model number but on the front it says "Hawking 100base-TX 4-port Hub". Yes I've had it a long time. I just googled it and found the model number which is IH400TX. I just figured that I needed to either get a gigabit switch or a gigabit router. Later today I will try another test with the nic set at 100. I tried using my wireless netbook to transfer files from the pc to the Nas. It took a lot longer of course but I wasn't getting nearly as many errors. Maybe 1 out of 10 usually at the start of the file transfer.
