marksb
Dec 11, 2011Aspirant
WD20EARS-00MVWB0 Westerd Digital Cavier Green 2TB
Hi, I just got a Duo V2 and a Western Digital drive. I didn't realize there were two different versions (wished I came here first). The drive worked fine so I ordered another one, not sure what ver...
Dec 28, 2011Guru - Experienced User
Upgrading to a gigabit home network is a good idea, you will get a lot faster transfer speeds if you do. Though you will need CAT 5e or CAT 6 cabling (if you are running over any distance).
Though of course these weird disk full errors should be fixed. If you are following other threads, you will see that some other folks are getting the same error (with different disks). I believe that all are running the new ARM products.
