marksb
Dec 11, 2011Aspirant
WD20EARS-00MVWB0 Westerd Digital Cavier Green 2TB
Hi, I just got a Duo V2 and a Western Digital drive. I didn't realize there were two different versions (wished I came here first). The drive worked fine so I ordered another one, not sure what ver...
marksb
Dec 28, 2011Aspirant
Well, now this is interesting. I have a Realtek nic onboard on an ASUS motherboard. It has a setting for Speed & Duplex that cannot be changed from auto. It has another setting for Auto Disable Gigabit with values of Disabled, Re-LInk, Battery and Re-Link, Battery or AC. I did a direct connection with it set to Re-Link, Battery or AC and did not get the error. So I left it and reconnected the Nas and pc to the router and...........yep, no error. As soon as I reset it to Disabled, I get the error. So now I have a fix until I upgrade the router. I wished I had a gigabit switch that I could try but if it works with the direct connection then I shouldn't have any problems right?
Thanks guys.
Thanks guys.
