Cluster2k
Sep 06, 2012Follower
WD20EARX - NV+ v1 - Dead drive?
Hi I've been using my Netgear NV+ 4000 v1 for a month and so far have been happy with it. However, last night I received a dead drive error on slot 1. The drives are 2x WD Green 2TB - WDC WD20E...
benoitmabille1
Sep 01, 2013Tutor
Hello,
I suggest that you watch your disks load cycle count, it is increasing rapidly.
Mine got over 750,000 which is well above the limit of 300,000. Because of this my WD20EARX are failing. They hang every few minutes.
The solution is to use 'wdidle3' and increase or even remove the idle timer (Google to get some info)
Benoit
ReadyNAS Ultra 6
6 x WD20EARX firmware 51.0AB5
Benoit
ReadyNAS Ultra 6
