Cluster2k
Sep 06, 2012Follower
WD20EARX - NV+ v1 - Dead drive?
Hi I've been using my Netgear NV+ 4000 v1 for a month and so far have been happy with it. However, last night I received a dead drive error on slot 1. The drives are 2x WD Green 2TB - WDC WD20E...
benoitmabille1
Sep 02, 2013Tutor
Tx for the suggestions
You think there could be swapping resulting in freezes ?
I will check (i use twonky not readydlna but principle remains i guess)
About the disks, i totally agree. No resync 6 times.
I have a faint hope that WD may accept replacement under warranty. Otherwise I will go for the 3TB ones.
Cheers
Cheers
