Cluster2k
Sep 06, 2012Follower
WD20EARX - NV+ v1 - Dead drive?
Hi I've been using my Netgear NV+ 4000 v1 for a month and so far have been happy with it. However, last night I received a dead drive error on slot 1. The drives are 2x WD Green 2TB - WDC WD20E...
Oct 05, 2013Guru - Experienced User
What firmware are you running on the ultra?
I am thinking that you should check the fullness of the OS partition with ssh (using "df .")
If the OS partition isn't full, then maybe you could try rebuilding the NAS from scratch (factory reset, reinstall add-ons, reinstall config, restore data from backup). A variation is to do a clean install using a couple of the old disks, restore enough of your data to get by, and see if the freezes stop.
