PhilStark
Mar 09, 2016Aspirant
WD60EFRX (6To Red WD drive) on ReadyNAS 102
Hello I purchased a Western Digital 6To RED Drive (reference WD60EFRX) thinking it would be compatible with my ReadyNas102 but it seems I was mistaken as it's not entering the slot properly. Di...
- Mar 09, 2016
PhilStark wrote:
You're talking about remove the plastic brackets which appear here for example ? The black plastic which moves back & forth.
Yes. That plastic should be removed for drives that don't have the standard side mounting holes. That includes 2.5 iinch drives and some high-capacity 3.5 inch drives.
Though I don't recall needing to do that with the WD60EFRX. I'll check when I have a chance.
PhilStark
Mar 09, 2016Guru - Experienced User
- StephenBMar 09, 2016Guru - Experienced User
My two WD60EFRX have the side mounting holes in the usual position. The black plastic inserts are in place, and the drives fit properly in the tray. And of course the tray also slides smoothly into the slot.
You are matching the drive orientation shown here? http://kb.netgear.com/app/answers/detail/a_id/22894/~/readynas-os-6%3A-adding-a-disk-to-desktop-models
- PhilStarkMar 10, 2016Aspirant
Thanks !
Somehow I damaged one of the plastic insert so I removed it completed and screwed the drive on the tray and managed to insert it in the slot. All good !
Don't know why I didn't make it the first time. Maybe it was too late and I needed sleep instead of trying to insert a drive into my NAS :manlol:
Thanks again !
