InteXX
Jan 20, 2015Luminary
WDC Reds Not Suitable?
I just finished reading this writeup: http://www.smbitjournal.com/2014/05/understanding-the-western-digital-sata-drive-lineup-2014/ This comment, about halfway down in the Red section, stood out...
Jan 20, 2015Guru - Experienced User
InteXX wrote: All BitRots are UREs, but not all UREs are BitRots. This would support your statement that "BitRot protection isn't relevant, as there is no silent corruption happening," as BitRot protection only protects against BitRot-sourced UREs. Correct?
URE -> you get no data when you try to read the disk sector, instead you get an error indication from the disk. RAID can correct it.
bitrot -> you get wrong data when you read the disk sector, and you get no error indication from the disk. RAID can't correct it. BitRot protection can correct it (at least sometimes).
