Damien89
Dec 03, 2014Aspirant
What does this mean in raidar?
Today the electricity in our neiborhood turned off all of a sudden, now when i turned everything on i have a yellow light in raidar, what does it mean? (readynas duo v2)
- NhellieVirtuosono. OS reinstall will not erase data but it will put the IP back to DHCP and reset the admin password.
- RXLuminaryHello Damien89,
Check these links below as reference guide in doing OS reinstall on your Duov2:
http://kb.netgear.com/app/answers/detail/a_id/20898/~/readynas--accessing-the-boot-menu
http://kb.netgear.com/app/answers/detail/a_id/21100 - Damien89AspirantIv'e did the os reinstall but its still the same, is warranty 3 years on the duo v2?
I think next i should test both hdd's, i will remove the hdd's, mark them which is which and test them with wd lifeguard since they are wd hdd. if i should do anything different please instruct me.
Thanks. - vandermerweMasterYes test the disks.
While you are testing the disks you could try to factory default the nas with a spare disk.
This will of course wipe the disk. If the unit sets up normally it basically excludes a chassis problem. If that is the case you could factory default with the 2 original disks if they are ok and restore your data from your backup.
The warranty is 3 years so you should contact support if in warranty. - Damien89AspirantHi, today i tested both wd disks with wd lifeguard. One of the disks did not pass both the quick test and extended test. Tomorrow i'm gonna take the drive to the shop i bought it from and see if they will replace it under warranty. I will take the test results with me to show it to them.
- vandermerweMasterLook for the wd RMA procedure on their website.
http://support.wdc.com/warranty/ - StephenBGuru - Experienced UserGenerally your retailer will replace a failed drive with a new one if you contact them within a couple weeks of purchase.
After that you end up RMAing the drive to the manufacture (WDC in this case), and you get a re-certified replacement. - Damien89AspirantI went to the shop i bought it from and they tested the drive and it failed their test, they were gonna give me a replacement drive but i opted to pay a bit extra (13 euros) and got a 2tb wd red drive instead of 1tb. Put it in the nas and after the nas copied everything it looks like everything is back to normal. :D
Thanks for your help everyone :thumbsup:
- Sep 11, 2022Retired_Member
