aaseef021
Dec 16, 2019Aspirant
What is supported
I had a couple of questions, please answer them 1. My ReadyNas is on Firmware 6.10.2, is Debian 9 or 10 supported, if not what do I need to do to get it to work with Debian 9 or 10 2. My mono...
- Jan 07, 2020
If your OS is up to date, it's already Debian 9. Other than that, I will simply repeat myself: You can count on nothing still working if you update Debian on the NAS.
I don't klnow how much more clear I can be.
Sandshark
Dec 16, 2019Sensei
Firmwate 6.10.2 is Debian 9 based. You cannot update the Debian base of the firmware and retain the NAS capabilities. You should be able to update mono with apt-get update && apt-get upgrade mono. It is not recommended to do a global apt-get upgrade.
aaseef021
Dec 17, 2019Aspirant
Hi
Thank you for the answers, I had couple more questions if you can answer please. Thank you
1. If I were to update to Debian 9, what are some of the NAS capabilities that will not work?
2. In the future do you plan to have a firmware that support Debian 9 and 10 and retain the NAS capabilities?
3. What version of Mono will this command install? apt-get update && apt-get upgrade mono
4. What is the latest version of Mono that is supported with Debian 8? and how can I install the latest version of Mono on Debian 8?
5. Can I upgrade Debian to Ubuntu? Will this work and retain the NAS capabilities?
