freddyfruitbat
Sep 18, 2012Guide
What is the difference between the ReadyNAS Duo v1 and v2?
Well, I checked the FAQs and that's the wording of the question I need... but unfortuately the answer is blank, so hopefully I'll be forgiven for asking here... Basically - I'm in the market for a ...
freddyfruitbat
Sep 18, 2012Guide
Thanks for the replies.
Honestly... I just don't know! I don't really get what they do, which is what I was trying to say above - to use the example of the Squeezebox; where would I stand using that with a Squeezebox-add-on-enabled v1, versus with a non-Squeezebox-enabled v2?
PapaBear wrote: If a robust menu of Add-Ons is important to you
