miogpsrocks's avatar
Apr 20, 2017
What is the largest hard drive I can put in a Netgear ReadyNAS Pro Pioneer Edition?
What is the largest hard drive I can put in a Netgear ReadyNAS Pro Pioneer Edition?  I think it uses XRAID 2( not 1).
I did a superficial search and I think I saw something about a 16GB volume limit. Is that true? If so then 3GB is the largest in a RAID 5 configuration.
RAID system has no data on it and I am buying the drives now so its not an expansion issue.
If 16GB is the largest volume, then can you split it into 2 volumes with both being under 16GB?
Thanks.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    You mean 16TB not 16GB.
    You can do a factory reset with equal capacity disks in place and get a larger volume.
    You can also have multiple volumes each under 16TB.
    OS6 doesn't have the expansion limits. So you could consider running that though doing so is not supported.
    • miogpsrocks's avatar
      miogpsrocks
      Tutor
      Yes, I mean 16TB not GB.
      Is this a real limit or does this not apply if you are formatting it from scratch with equal drives? I want to have 1 big volume if possible.
      So let's say I have 6 X 4TB hard drives in RAID 5 configuration. Will I end up with something around 20TB?
        mdgm-ntgr
        It doesn't apply when creating a volume with equal capacity disks. It only affects expansion. Note OS6 is not affected by the expansion limit, so if you'd like to expand the volume in the future then that may be worth considering even though not supported.
        Yes you'd get a volume that's about 18TiB. 20 * 1000^4 / 1024^4 = 18.2 (note this calculations ignores overheads, root volume, swap etc.). We use base 2 whereas disk manufacturers use base 10. So we may get a smaller number but it's still the same amount of space.
        Users have used much higher capacity disks than 4TB ones.
ProSupport for Business
