rmacbeth
Aug 19, 2016Apprentice
What would be the best setup for Raid with 4 bay NAS
With the 4 bays what would be the best setuo for Raid? Also with the WD red what version should I get the reg red or the pro. I looking at either 4 2TB drives or 4 4TB drives. The cost difference c...
- Aug 23, 2016
You can't make LAGs on the GSS108E but you can make static LAGs on the GSS116E. Neither of them support LACP LAGs.
http://www.downloads.netgear.com/files/GDC/datasheet/en/Click-Switch.pdf
If you really want to make a LAG, you could create a static LAG on the GSS116E and a Round Robin bond on the NAS, which would be the correct configuration.
Unless you have a good reason to think so, using an LACP LAG between the NAS and GS108T, then a static LAG between the GS108T and the GSS116E is not going to have any benefit over simply using a direct static LAG.
I personnaly avoid ALB, but that's only my opinion ;)
rmacbeth
Aug 20, 2016Apprentice
StephenB thanks for the answers to my questions. I have a 1GB backbone with Netgear switchs along with r7800v2 router connected with Cat 6 cableing. I will get 3 4tb red's I also in the camp with less heat better drive live. I have two Click switchs one being GSS116E and a GSS108E. The question I still have is with the RN214 Link aggregation will the GSS116E LAG configurantion be able to use for this?
Thanks
Rich
Aug 20, 2016Guru - Experienced User
I don't think the GSS116E supports LACP - if that is correct, then you won't be able to use the GSS116E LAG.
You can still try to use the ALB bonding mode in the RN214 - that doesn't require special switch support. Sometimes it does misbehave - if you see odd behavior, disconnect the second NIC and just to make sure its not related to bonding.
- rmacbethAug 20, 2016Apprentice
StephenB I heard that might be a problem. I take it that the GS108T would be a good fit. I can get one for approx $80 and put it in frount of the GS116E.
Thanks so much for all your help
Rich
- StephenBAug 20, 2016Guru - Experienced User
The GS108T does support LACP. You'd need a static lag between the GS108T and the GSS116E, and LACP between the GS108T and the RN214.
You will only see a performance benefit if you have multiple simultaneous connections from devices on the GSS116E (or GS108T) and the NAS.
I'd probably wait on the GS108T and try ALB first.
