rmacbeth
Aug 19, 2016Apprentice
What would be the best setup for Raid with 4 bay NAS
With the 4 bays what would be the best setuo for Raid? Also with the WD red what version should I get the reg red or the pro. I looking at either 4 2TB drives or 4 4TB drives. The cost difference c...
- Aug 23, 2016
You can't make LAGs on the GSS108E but you can make static LAGs on the GSS116E. Neither of them support LACP LAGs.
http://www.downloads.netgear.com/files/GDC/datasheet/en/Click-Switch.pdf
If you really want to make a LAG, you could create a static LAG on the GSS116E and a Round Robin bond on the NAS, which would be the correct configuration.
Unless you have a good reason to think so, using an LACP LAG between the NAS and GS108T, then a static LAG between the GS108T and the GSS116E is not going to have any benefit over simply using a direct static LAG.
I personnaly avoid ALB, but that's only my opinion ;)
omicron_persei8
Aug 23, 2016Luminary
rmacbeth
Aug 28, 2016Apprentice
My NAS will be here this tuesday (the drives already were delivered) I was going to give the static LAG a try since I do have the GSS116E hooked up to my R7800 that way I can give it a try. If it does not handle what I have then I will look into getting a GS108T and not use the Static LAG on the GSS116E. I let you know what I find out later on this coming week.
