rmacbeth
Aug 19, 2016Apprentice
What would be the best setup for Raid with 4 bay NAS
With the 4 bays what would be the best setuo for Raid? Also with the WD red what version should I get the reg red or the pro. I looking at either 4 2TB drives or 4 4TB drives. The cost difference c...
- Aug 23, 2016
You can't make LAGs on the GSS108E but you can make static LAGs on the GSS116E. Neither of them support LACP LAGs.
http://www.downloads.netgear.com/files/GDC/datasheet/en/Click-Switch.pdf
If you really want to make a LAG, you could create a static LAG on the GSS116E and a Round Robin bond on the NAS, which would be the correct configuration.
Unless you have a good reason to think so, using an LACP LAG between the NAS and GS108T, then a static LAG between the GS108T and the GSS116E is not going to have any benefit over simply using a direct static LAG.
I personnaly avoid ALB, but that's only my opinion ;)
omicron_persei8
Sep 02, 2016Luminary
What do you mean two Static LAGs?
You need to have a single Static LAG (two ports) on the switch and a Round robin bond on the NAS (both NICs).
1) create the Round robin on the NAS.
2) create the Static LAG on the switch
3) wire it (both NICs of NAS to the two switch ports members of the Static LAG).
