tweeks
Dec 21, 2012Aspirant
Where do I get additional drive trays? (forReadyNAS Ultra 2)
I have a ReadyNAS Ultra 2 [X-RAID2] w/RAIDiator 4.2.21 and I need at least two more drive trays. I can't believe that no one sells extra drive trays. Any legit RAID system will have extra drive tra...
Dec 22, 2012Guru - Experienced User
Agreed. The only reasons I can see to buy one are to replace one that got damaged somehow, or get rid of the old-style trays that jam. But they are available.
mdgm wrote: Apart from replacing a failed drive there really is no need for a spare drive tray. Even then it doesn't take long to remove four screws etc. whereas a resync will take hours. Unless you need to send the drive to someone who would struggle to do that and get them to install it, I don't really see the need for a spare drive tray.
