muetze's avatar
muetze
Where to buy a power supply for NV+??
Hi guys,
seemes that the power supply of my NV+ screwed up.
it smelled a little bit ...
pressing the power on button has no effect any more ...
does anyone now where to buy a new power supply for a readynas NV+
  • If your NV+ is less than three years old it should be under warranty. Open an on-line case with technical support.
    You may also want to try Amazon.co.uk. While the listing is in pounds and they ship free in the UK, they may ship to the rest of the EU and accept Euros.
    Googling from Europe may also turn up other sources that are not showing up on my searches. the correct part number of RND4PSU1-1000s is shown on the Amazon listing. Just Google Netgear RND4PSU1-1000s and see what you get.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    If it was purchased on/after Aug 21, 2007 it should still be under warranty. Sometime in 2009 I think the warranty length changed to 3 years. I'm not sure exactly when though it would have been after the NVX was available.
ProSupport for Business
