dragos1's avatar
dragos1
Where to buy a replacemnt readynas 102 power adapter
Where can I buy a replacement power supply for netgear readynas 102. 12V
Thank you
  • Is your RN102 already Out of Warranty? If not yet, I advised you to contact Netgear support so that you do not have to buy anymore. Refer on this link: http://support.netgear.com/general/contact/#tab-call -Be aware that support expert might ask you to provide a copy of the Proof of Purchase for verification.
    If ever your RN102 is already Out of Warranty, then you may just check on local and online stores. Just make sure that the power adapter that you will purchase has the same specifications as with the original power adapter that came with your RN102.
  • I'm trying now to contact Neatgear as I can't find any approved replacement to buy. Only Chinese cheap stuff
  • original netgear power supply also made in china. probably from same factory. they are cheap.
    just use those like batteries. after 2 years if fail then throw away and replace by a cheapo.
ProSupport for Business
