Dewdman42
Aug 26, 2025Virtuoso
Which backup method?
So there are two primary backup methods provided in frontview, for purpose of backing up my volume data. There is the so called "File Backup" and there is ReadyDR. I'm assuming my machine (524x) su...
Dewdman42
Sep 04, 2025Virtuoso
I assume you mean check the box that says only create automatic snapshots if there are actual changes..
I see what you mean though if I have daily all the way for say 3 months or 6 months and its only snapshotting changes...then it still shouldn't get that big really, any bigger in size then if they are thinned out to weekly, whatever big changes are in there will been the weekly ones, etc. so it won't save any space, it would just theoretically simplify what you look at or perhaps mimic Time Machine in some way...but I take your point. Thanks for pointing me to snapper though I will check that out also.
Sep 04, 2025Guru - Experienced User
Dewdman42 wrote:I assume you mean check the box that says only create automatic snapshots if there are actual changes
yes
Dewdman42 wrote:I should have brought this ultra2plus back into action a long time ago, actually I'm impressed at how well it runs basic stuff, no plex or anything, but its handing iSCSI and rsync like a champ
If I recall correctly, the Ultra 2 Plus hardware is the same as the Pro 2. Fast enough to saturate a gigabit ethernet connection for basic storage. My Pro 6 is still in service as part of my own backup plan.
- Dewdman42Sep 04, 2025Virtuoso
I haven’t been able to saturate the 1gbit Ethernet yet while reading or writing. I can with iperf3 net tests I got 117MB/sec. But I don’t know what tool to use to find out max reading and writing coming also through network, and anyway the new hdd I ordered will be probably faster then this cheap old barracuda I’m testing with now. Doing an iscsi based backup from a Mac through apfs file system over iscsi and doing whatever overhead involved in backup software etc was maxing out about 50MB/sec but I don’t think ultra2plus was the bottleneck. And that is still pretty fast enough.
CPU is barely sweating, I think the hardware is fine for this use, but I recall it struggling with plex transcoding back in the day and I don’t even do any crazy transcoding. It also could not handle crashplan back then mainly because of not enough ram, but it may have been os4 and 1gb I can’t remember now. It was one of the reasons I bumped up to the 524x with ram upgraded to 16gb ecc
