Dewdman42
Aug 26, 2025Virtuoso
Which backup method?
So there are two primary backup methods provided in frontview, for purpose of backing up my volume data. There is the so called "File Backup" and there is ReadyDR. I'm assuming my machine (524x) su...
Dewdman42
Sep 23, 2025Virtuoso
Thanks for that and thanks for the heads up about HDSentinel, never heard of that one before but will check it out too.
Sandshark
Sep 24, 2025Sensei - Experienced User
FWIW, here is the script I run on my backup machine:
#!/bin/sh
date >/data/hdsentinel/hdinfo_RD516A.txt
echo >>/data/hdsentinel/hdinfo_RD516A.txt
/apps/hdsentinel/HDSentinel -solid >>/data/hdsentinel/hdinfo_RD516A.txt
df -h >>/data/hdsentinel/hdinfo_RD516A.txt
btrfs fi show >>/data/hdsentinel/hdinfo_RD516A.txt
for i in $(findmnt --mtab -nt btrfs --output TARGET | grep -v '/*./')
do
echo $i >>/data/hdsentinel/hdinfo_RD516A.txt
btrfs fi usage -T $i >>/data/hdsentinel/hdinfo_RD516A.txt
done
rnutil get_disk_info >>/data/hdsentinel/hdinfo_RD516A.txt
/apps/hdsentinel/HDSentinel -r /data/hdsentinel/hdsreport_RD516A.html -html
rnutil create_system_log -o /data/hdsentinel/log_RD516A_$(date +%F).zip
find /data/hdsentinel -maxdepth 1 -mtime +6 -type f -delete
rsync -lptgoD /data/hdsentinel/*RD516* rsync://192.168.0.42/hdsentinel
The one I run on my main machine is essentially the same without the rsync since my scheduled backups already do that and I don't want it trying to send to a backup unit that's off. I run it hourly, so it overwrites the previous logs for that day for however long it's on doing the backups. I don't bother to keep the old reports for HDSentinel, but you could name them to include a time/date as well if you want to save them. If you want hourly history, you can use a file name that includes the time so they don't overwrite. I also trim to the last 7 days, but you can adjust that as well.
BTW, hdsentinel is just an executable, so no need to do any install or keep it out of the OS partition. It does nothing unless you tell it to, so it won't fill the OS partition with reports unless you inadvertently tell it to put them there. I put in in /apps because I was unsure at the time if I needed to, and I just left it there when I found it unnecessary.
- StephenBSep 24, 2025Guru - Experienced User
Mine is more complicated and runs as a service. This runs on both the primary NAS (MainNasIP in the script) and the backups. There is some unusual syntax which was needed to get it to run on both the v1 and OS-6 NAS.
There is an alternative method used to create the logs on the NV+ and Duo v1 that is triggered if rnutil does not exist on the NAS. It's not exactly the same as the actual log zip, but it is close enough.
#!/bin/sh # # set up some useful variables # MainNasIP=10.0.0.15 NasIP=`exec hostname -i | awk -F " " '{print $NF}'` RemoteShareName=Logs test "$MainNasIP" != "$NasIP" \ && { ShareName=LocalLogs; \ Retention=7; } \ || ShareName=Logs; \ test -e /usr/bin/rnutil && LogShare=/data/$ShareName || LogShare=/c/$ShareName LogFolder=$LogShare/$(hostname) HDSentinel=/apps/HDSentinel/HDSentinel timestamp="$(date +%Y%m%d_%H%M%S)" RsyncFilter="--include=$(date +%Y)/ --include=$(date +%Y-%m)/*** --exclude=*"; test -e /usr/bin/rnutil && RshParm=-rsh=rsh # # make output folder if not there # test -d $LogFolder || mkdir $LogFolder # # Save Logs in /Logs/hostname/year/year-month # build the longer folder name in two steps, so mkdir works # LogFolder=$LogFolder/$(date +%Y); test -d $LogFolder || mkdir $LogFolder; LogFolder=$LogFolder/$(date +%Y-%m); test -d $LogFolder || mkdir $LogFolder; # # get system logs with rnutil on OS-6, otherwise zip /var/logs # rnutil will create an empty file named "1" in its folder; which is harmless. But let's delete it anyway # get smartctl data (somewhat different command for OS-6 than OS-4) # test -e /usr/bin/rnutil \ && { rnutil create_system_log -o $LogFolder/$(hostname)-$timestamp-System.zip;\ rm ./1;\ for i in a b c d e f g h i j k l m n; do smartctl -a -x -l defects /dev/sd${i} | egrep -v "local build|No such device|smartmontools"; done >>$LogFolder/$(hostname)-$timestamp-Smart.log; }\ || { /apps/Scripts/diag >/tmp/diagnostics.log;\ /apps/Scripts/90_CreateLogs;\ zip -r -j $LogFolder/$(hostname)-$timestamp-System.zip /ramfs/log_zip/*;\ test -d /ramfs/log_zip && rm -rf /ramfs/log_zip;\ test -e /tmp/diagnostics.log && rm /tmp/diagnostics.log;\ for i in a b c d e f g h i j k l m n; do smartctl -a -x /dev/hd${i} | egrep -v "local build|No such device|smartmontools"; done >>/$LogFolder/$(hostname)-$timestamp-Smart.log; } # # log HDsentinel info if present # test -e $HDSentinel && $HDSentinel -r $LogFolder/$(hostname)-$timestamp-HDSentinel # # Apply retention limits if variable set # test "$Retention" != "" && find $LogShare/$(hostname)/* -mtime +$Retention -exec rm {} \; test "$Retention" != "" && find $LogShare/$(hostname) -type d -empty -delete # # rsync logs to the main NAS if this is a backup NAS # this requires that rsync be enabled as read-write on the destination share. # retention is not being applied to the destination share # test "$MainNasIP" != "$NasIP" && rsync $RshParm -amv $RsyncFilter $LogShare/$(hostname)/* $MainNasIP::$RemoteShareName/$(hostname) exit 0
update_logs.service is
[Unit] Description=Capture Logs Service After=network-online.target multi-user.target [Service] Type=oneshot RemainAfterExit=no ExecStart=/apps/Scripts/update_logs [Install] WantedBy=multi-user.target
and update_logs.timer
[Unit] Description=Capture Logs Service [Timer] OnCalendar=*-*-* 22:59:00 Unit=update_logs.service [Install] WantedBy=multi-user.target
- Dewdman42Sep 25, 2025Virtuoso
Thanks to both of you for your backup scripts, I will check them out in detail and see what I want to do.
One more question. in the front view there is a backup log that shows up after the backup is complete, which shows every file that was backedup. Do either of you know where that file is created and updated while the backup is in progress?
- StephenBSep 25, 2025Guru - Experienced User
The backup logs are in /var/log/frontview/backup/
yea I look at those already but those are not the same logs shown in front view. At the end of backup front view log shows a bunch of information about the time and date of the backup and also shows a line for every file that was backed up. That information is not contained in /var/log/frontview/backup/ anywhere that I have been able to find.
- StephenBSep 26, 2025Guru - Experienced User
Did you look in the backup_XXX_copy.XXXXXXXXXX.log files?
The last field is an epoch timestamp, you can convert it to human-readable time using https://www.epochconverter.com/
The linux date command will also convert it. (date -d @XXXXXXXXXX)
FWIW, I don't think the info you see in Frontview is coming from one file. I think it is assembled, and the specifics might depend on what protocol you are using for backup.
With rsync backup, I think I normally just see what is in backup_XXX.log in Frontview. But I don't look there much, as my backup NAS are almost always powered down.
- Dewdman42Sep 26, 2025Virtuoso
That file appears to be created at the end of the rsync job, even if it is a very long running job...is not there until its over. So the logging that happens while the job is actually running must be somewhere else. From snooping around my instinct is that its in syslog somewhere and then must be extracted out at the end. I don't really know enough about syslog to figure out where that is though.
