DOA
Oct 05, 2011Aspirant
Why can't I get support? Ticket 16849963
here are the facts:
1) June 14 2011 bought new NV+ and 4 Barracuda 2TB HD from Fry's, checked compatibility list they should work.
2) Spent a week setting it up and some other equipment. Mixed Windows 7 and XP so it took a while to get all the computers to play nicely. The NV+ was on and off the network. I attributed it to my Windows issues, especially the failed homegroup vs XP issues. Eventually I gave up and went all Win7.
3) July 4 weekend began moving my movie collection to the NV+, only transferred for 4 hours and the NV+ went off the network.
4) Multiple tries with Windows configurations (again figuring that was the problem) but the NV+ was unhappy, never more than a handful of movies would transfer. Once on the NV+ they sorted, played and were happy.
5) Tech friend that has an NV+ said that many files may need more RAM - back to Fry's and in four more trips I got RAM that passed testing. Tested all next night and it passed.
6) Slowly transferred the rest of the movies. I have Gigabit network and it was going slow Ethernet speeds. 1.8 TB in three shots got most of them on the NV+.
7) August 7 NV+ off line, reboot restored the NV+to the network.
9) August 12 NV+ off line, reboot restored it and I started looking for reasons here in the forums. Most common reason seemed to be DHCP server not available at the end of the NV+ lease. I increased the DHCP lease time.
10) August 14 NV+ off line. Interesting, the lease was not up so DHCP was not looking like a problem.
11) August 16 NV+ off line again. One more time to be sure.
12) August 20 NV+ off line. Might have been earlier, but I had to travel for work. Still just under the 96 hour DHCP lease time.
13) August 26 NV+ off line. Again might have been earlier. Called tech support and gave up after half an hour trying to get through.
14) Sept 10 NV+ off line. No idea when as I was away from home working.
15) Sept 15 got through to Tech support tier one and they said "although the warranty is five years that is only on hardware, if you have a configuration or software problem we cannot help you after 90 days". Tech suggested reading more of these forums.
16) Now pretty fed up so I am not dedicating a lot of time to this, tried a bunch of ideas I read here, none worked.
17) Oct 5 day off work so I called Tech support, same litany "we cannot help you ... software". Name calling worked to get me a case number and tier 2 support, unfortunately 10 minutes on hold and voice mail asking my case number. No call back in 3 hours of waiting.
18) posting this in hopes NETGEAR or a user actually wants to help.
$1,000 in hardware that I need to boot up every time I want to use it is not much of an NAS.
- DOAAspirantThe NV+ goes for days, then drops off the network. Still powered up, hitting the power button shows correct IP, but no response. Reboot restores functionality.
See previous posts.
Swapping cables and ports does nothing, trying other options. - DOAAspirantSo long since my last post, but this has taken forever it seems.
In the end I had a bad power supply for the 16 port network switch. The 12V 1.5A plugin was failing and the first casualties were always the Network Storage. Why they always failed to stay on the network while others managed must be found in the network stack. I am guessing Windows is a little more tolerant and could re-connect. I took computers off line and added them in different orders so many times, only had a 4 port spare switch which worked with all combinations.... Then it dawned, I always failed at 5 or 6 devices on the 16 port switch, no matter which ones, 5 or 6 devices dropped the Network storage in one to three days. That led me to the switch power supply, it could not handle the traffic for extended periods.
THANKS for your support and I need to mention traditional troubleshooting never came up with consistent results. But I just kept at it! - PapaBear1ApprenticeIntermittent or delayed failures are always the hardest to find. Congrats on your perseverance and thank you for your feedback. It may help someone else down the road. I know you are glad to finally know what the problem was.
- Sunday_Afterno1AspirantEchoing Papabear - congratulations! That was a tricky problem to resolve.
