MickeyG71
Mar 15, 2014Aspirant
Why does my ReadyNAS NV+ v1 (RND4000 v3) see 750gb WD30EZRX
Hi All, This is my first post on this forum so please be kind! I've just got my self a NV+ v1 (RND4000 v3) and recently added 4 x WD30EZRX (3TB drives) My issue is simply that only 750gb of the 3...
chirpa
Mar 15, 2014Luminary
Did you just update the firmware after installing the disks? That sounds like an old firmware issue. Since you have no data on the disks yet, I'd try a factory default now that 4.1.13 is on the system.
You can do this in FrontView under System>Update>Factory Default. Or by the boot menu: http://www.readynas.com/kb/faq/boot/how ... v_nv_x6600
