neverbuyagain
Jan 25, 2023Tutor
Will never buy again and recommend to never buy if expect support for critical data...
I have an old, obsolete ReadyNAS 314 that was used as a file vault for critical data. Long story short, a disk failed, RAID won't rebuild and several posters have had the same problem. Usually they...
schumaku
Jan 27, 2023Guru - Experienced User
neverbuyagain wrote:
I have an old, obsolete ReadyNAS 314 that was used as a file vault for critical data. Long story short, a disk failed, RAID won't rebuild and several posters have had the same problem. ... Just so happened we need something off that NAS and I am now screwed.
Sorry, you screwed yourself. You failed on the most simple data protection and backup plans actions for what you define as a vault for critical data, knowing the storage system is obsolete, isn't it? I would fire the person in charge operating a storage system, without any plan on a backup and continuity plan. It's not the vendors responsibility to be ready for fixing what the could be named a plan. Even it it's just about replacing a storage block and trigger the RAID to rebuild the redundancy.
- Jul 21, 2021Retired_Member
