motah33
Sep 24, 2011Aspirant
Will this UPS work with the ReadyNAS?
Hi, Is anyone using the following UPS successfully with their ReadyNAS Duo: http://www.apc.com/resource/include/techspec_index.cfm?base_sku=SUA1000I. Specs: PC Smart-UPS 1000VA USB & Serial 230V...
mdgm-ntgr
Sep 24, 2011NETGEAR Employee Retired
I'm using it with a NV+ (4-bay version of Duo). It works fine. Connect the NAS's power to the UPS (you'll need to buy an adapter to be able to do this, I think) and hook up the supplied USB cable between the USB port on the UPS and one of the rear usb ports on the NAS.
Welcome to the forum!
