Kitias
Apr 05, 2011Aspirant
Windows 7 NV+ Compatibility/Support
Has there been any update on when the NV+ will support Windows 7? Mine is sitting collecting dust. It's almost to the point of ditching it completely and getting one from a company that supports a...
Kitias
Here are my current specs.
Windows 7 Ultimate 64bit (With all updates applied.)
Firefox 4.42.0.0
NV+ RAIDiator Ver 4.1.7
ReadyNAS Remote Addon Ver 1.0.9.51
ReadyNAS Remote Ver 1.6.5.11
I have tried all the known fixes.
Network security: LAN Manager authentication level - Send LM & NTLM - use NTLMv2 session security if negotiated.
Minimum session security for NTLM SSP - Disable Require 128-bit encryption
Disabled Windows Firewall and Uninstalled Anti-Virus.
Checked Routes all appear to be correct.
Disabled IPv6
Changed homegroup setting.
Enabled network discovery
Enabled file and printer sharing
Changed Encryption form 128bit to lower.
I have also tried the ReadyNas remote setup. I have an active account that shows that it was able to log in and connect to the NAS. If you try to connect all it does is failout and open My Documents.
Just to make sure I wasn't missing I did a factory reset on the ReadyNas and then upgraded to the latest version of each. I also reinstalled ReadyNas remote also.
I can connect without issue with my XP box.
Please let me know if know of any other options.
-Edit added browser and version.
Firefox 4.42.0.0
Disabled IPv6
