Kitias
Apr 05, 2011Aspirant
Windows 7 NV+ Compatibility/Support
Has there been any update on when the NV+ will support Windows 7? Mine is sitting collecting dust. It's almost to the point of ditching it completely and getting one from a company that supports a...
sdouek
Apr 08, 2011Guide
I am with papabear I am using windows 7 prof 64 bit on 2 laptops a ibm and a dell no problems here. Using ie 9 and firefox 3.6.16 with no problems. And have both the nv and nv+.
What is you problem with the unit ?
What router and switch are you using?
Have you tried to connect via another computer running windows 7 ?
Try disabling jumbo frames. If jumbo frames is not set up properly you will get drops. Some older nics don't have the ability to do jumbo frames. My IBM laptop will only do 4k frames and no higher.
It sounds odd to me but remove the addons from windows 7 machine also and see if that helps.
