Kitias
Apr 05, 2011Aspirant
Windows 7 NV+ Compatibility/Support
Has there been any update on when the NV+ will support Windows 7? Mine is sitting collecting dust. It's almost to the point of ditching it completely and getting one from a company that supports a...
samjoconnor
Nov 02, 2011Aspirant
Kitias wrote: Sorry about the delay on replying. My job took me out of town for a little while.
My main issue is that I can't use any of the shares on the Readynas.
I can connect with Raidar and do all the setup and upgrades. I have already listed what I tried to get it working. Just to add more information I reloaded my main comp with XP and I had no issues connecting to the Readynas. Then I put Windows 7 64bit back on my box and same issue as before. This was with the nas connected directly to my comp. No router in the way.
When I try the readynas remote config it says it is online and able to see the ip that is assigned. When you try to use the connect to readynas option it opens my docs.
Per your advice I disabled jumbo frames and there was no change.
Also this isn't a case of slow connection or transfer speeds.
Any solution onthe opening My Docs issue? I am experiencing that on my Win 7 64 bit machine. Netgear Tech Support have no solution for my problem.
