Kitias
Apr 05, 2011Aspirant
Windows 7 NV+ Compatibility/Support
Has there been any update on when the NV+ will support Windows 7? Mine is sitting collecting dust. It's almost to the point of ditching it completely and getting one from a company that supports a...
PapaBear1
Nov 02, 2011Apprentice
1. Do you have a password set on the ReadyNAS?
2. Do you have a password set on the PC?
3. Are the user id and password the same on both? (Ignore if no password set on NAS.
4. What anti-malware suite are you running? If no suite, what individual applications (FWIW I am using Avast! and SuperAntiSpyware, although have used AVG in the past with no problems).
5. Have you tried a direct connection?
6. You placed your document folder on the NAS rather than individual data folders? Did you establish the Documents folder with Win7 on this machine or another machine?
