Kitias
Apr 05, 2011Aspirant
Windows 7 NV+ Compatibility/Support
Has there been any update on when the NV+ will support Windows 7? Mine is sitting collecting dust. It's almost to the point of ditching it completely and getting one from a company that supports a...
samjoconnor
Nov 04, 2011Aspirant
PapaBear wrote: You said you are using ReadyNAS Remote. Is the desktop a remote connection or on the network?
If you moved the MyDocument folder from another machine to the NAS, it might not permit you to access it from the desktop.
I have several data folders set up in the appropriate shares and have access from any of my machines. Do you have problems accessing files in either the backup or media shares?
The desktop is a remote machine. I have not moved the My Documents folder to the NAS. I can't access any shares remotely, I double click on the NAS and it takes me to C:\Users\Documents
