Kitias
Apr 05, 2011Aspirant
Windows 7 NV+ Compatibility/Support
Has there been any update on when the NV+ will support Windows 7? Mine is sitting collecting dust. It's almost to the point of ditching it completely and getting one from a company that supports a...
PapaBear1
Nov 04, 2011Apprentice
I don't use ReadyNAS Remote, so I can't help you there. Hopefully some who does may come along.
You might want to open a new discussion strictly about ReadyNAS Remote. The current heading is not directed that way. One of the problems with adding onto an existing discussion with a different problem.
