stevenestrada
Apr 29, 2019Aspirant
Wont boot after 6.10.0 update
Upgraded rn314 to 6.10.0
Like the last os upgrade, it hangs partially booted
Power cycle a few times, always gets stuck at a different percent, until it finally completes
No hardware problems in the gui log.
2 raid 1
Higest df = 75%
Do you think if I buy a new chassis that will fix it?
- additudeVirtuoso
I wouldn't do USB recovery at this point, because the system is eventually booting. So it doesn't seem likely that this is related to corruption of the flash.
You should download the full log zip file from the admin web ui. Then ask a Netgear mod (for example, JohnCM_S ) or perhaps Hopchen (former Netgear) if they are willing to analyze them for you. Put the log zip into cloud storage (google drive, dropbox, etc), and send the link in a Private Message (PM) to them. Don't post a link to the logs publicly here. The PM facility is reached using the envelope icon on the upper right of the forum page.
