dunkymole
May 26, 2014Aspirant
Won't run with 2 disks in
Hi,
ReadyNAS Ultra 2+
I recently woke up to no NAS on the network :-(
I did an OS reinstall and no joy. I then rebooted with first one disk out, then the other. The device seemed to work when disk 2 was no present so I bought another drive and inserted that. Same issue.
It looks like having any disk in bay 2 causes this: http://imgbin.org/index.php?page=image&id=17612
To add to all this, I have started getting fairly frequent emails with the following:
Unexpected enclosure status detected
V+12 power is out of normal range [expected: 12.00 current: 11.03].
The unit is still under warranty. Any ideas?
ReadyNAS Ultra 2+
- StephenBGuru - Experienced Usercontact support.
- dunkymoleAspirantI actually kind of thought that was what I was doing. I thought theses boards were monitored. Tips on how to get them?
support.netgear.com.dunkymole wrote: I actually kind of thought that was what I was doing. I thought theses boards were monitored. Tips on how to get them?
Use email if you purchased more than 90 days ago. - dunkymoleAspirantThanks
