Feb 18, 2022Guru - Experienced User
Workaround for ERR_SSL_VERSION_OR_CIPHER_MISMATCH problem for Sparc NAS (4.1.x firmware)
This workaround eliminates the redirection of http://nas-name-or-ip/admin to https://nas-name-or-ip/admin for NAS running 4.1.x firmware. It does require ssh to install.
Entering https://nas-na...
sonvolt99
May 02, 2022Star
Implemented change okay, but now getting connection request refured, cleared cache reinstalled chrome , checked firewall all okay , any ideas I could try?
- StephenBMay 02, 2022Guru - Experienced User
What NAS model and what firmware is it running? Did you install one of the two add-ons or did you edit virtual.conf?
- sonvolt99May 02, 2022Star
Hi Stephen,
Its a NAS Duo V1 running the 4.1.17 mod https://community.netgear.com/t5/forums/replypage/board-id/readynas-general/message-id/47827
, which I use to backup my Unraid self built NAS. I edited virtual.conf (both) the one in etc/frontview/apache
and one in etc/default/etc/frontview/apache.
The change worked as I no longer get the error ssl msg and got the correct response when I restarted frontview.
Since I only use it as a backup it's not a bit deal as I power it on once a week run a RSYNC from my Unraid server then
power off backup NAS with a curl script. I've tried chrome/edge & firefox all the same this site can't be reached refused to connect.Cheers
Ken
