Feb 18, 2022Guru - Experienced User
Workaround for ERR_SSL_VERSION_OR_CIPHER_MISMATCH problem for Sparc NAS (4.1.x firmware)
This workaround eliminates the redirection of http://nas-name-or-ip/admin to https://nas-name-or-ip/admin for NAS running 4.1.x firmware. It does require ssh to install.
Entering https://nas-na...
Magnyzz
Nov 19, 2022Tutor
I have a ReadyNAS Ultra 4 with firmware 4.2.30.
In your post you say your procedure is for 4.1.x firmware ... does it work also for 4.2.30 firmware?
(This is a reply to the first post by StephenB)
sonvolt99
Nov 19, 2022Star
See post 2 by StephenB , there is apparently an add-on for 4.2 systems , which would make the needed change.
