Feb 18, 2022Guru - Experienced User
Workaround for ERR_SSL_VERSION_OR_CIPHER_MISMATCH problem for Sparc NAS (4.1.x firmware)
This workaround eliminates the redirection of http://nas-name-or-ip/admin to https://nas-name-or-ip/admin for NAS running 4.1.x firmware. It does require ssh to install.
Entering https://nas-na...
Magnyzz
Nov 19, 2022Tutor
I have a ReadyNAS Ultra 4 with firmware 4.2.30.
In your post you say your procedure is for 4.1.x firmware ... does it work also for 4.2.30 firmware?
(This is a reply to the first post by StephenB)
Nov 19, 2022Guru - Experienced User
I haven't tested it (my 4.2.x Pro 6 was converted to OS-6 before this issue began). If you have a 4.2.x system that can be converted to OS-6 (not an NVX and some rackmount models), then I recommend doing that instead. That also gives you SMB 3.0, and several other features not in 4.2.x.
That said, I think my procedure will work on 4.2.x also.
The add-on that sonvolt99 refers to can be found here:
Note you can do both (making the change to allow frontview access from http w/o redirection, but also allowing https with TLS 1.2 to be used).
- MagnyzzNov 19, 2022Tutor
Thanks. I managed to solve it ... at least good enough for me. This is what I did.
1) I installed an old version (ver 91) of firefox on a usb-stick. This gave me access to the readynas admin web-page.
2) I installed https://github.com/rdynsxtrs/rn4bin/blob/main/apache2/x86/Apache2_2.2.34-x86-0.2.0.bin
as an add-on using the admin web-page. (FYI, I got an installation error at the end as somebody else also pointed out but after restarting the nas it seems ok).
After these two steps I now have access from my normal chrome-browser.
- jmzorkoJan 17, 2023Guide
Stephen,
This is quite an interesting thread. I also have a ReadyNAS NV+ that still works well, and i'd quite like to update it to use TLS 1.2. However, I don't know the filename or location in the RNXtras repo for this addon. Can you illuminate me?
John
- SandsharkJan 18, 2023Sensei
There is no SSL update for the NV+ V1 or Duo V1. Their unique SPARC processor makes it very difficult to to compile any update today. The only solution for those systems it to allow HTTP access to FrontView.
- nutsyboltsyMar 07, 2023Guide
Many thanks to all monitoring this thread!!!
I'm on a Window's 11 machine connecting to a ReadyNAS Ultra 2 running RAIDiator 4.2.31. I managed to get access to Frontview using Firefox 94.0.2 (disabling automatic updates per StephenB as soon as i opened firefox proved essential, in case anyone's struggling with that the way i did)
I have a similar question as did jmzorko, namely, I'm trying to identify the correct file to download then load as a local add-on into Frontview. Following https://rnxtras.com/ i found my way to https://repos.rnxtras.com/debian/. but it's not clear to me exactly which file from the many directories i should use. I rolled the dice and tried all the files i found in https://repos.rnxtras.com/debian/ntgr-r4x86/dists/r4x86/main/binary-i386/, however, "uploading and verifying" from the Add-ons tab resulted in each one giving me an error saying "Update file is not valid for this architecture."
So... I think i'm almost there - i just need to find the right file that will upgrade my NAS to use TLS 1.2. Can anyone point me to the exact file i should use?
Thanks!
Phil
- SamirDMar 07, 2023Prodigy
Yep, and playing whack a mole with that update setting will try your patience. I have a portable version of ff 73 that I've seen automatically upgrade to 100+ without my permission as it just likes to sneakily change that setting every so often. My solution was to copy my version of 73 and start with it each time. A royal pita though and since portable ff52 works great for the readynas I don't mess with the later versions for accessing frontview.
