Feb 18, 2022Guru - Experienced User
Workaround for ERR_SSL_VERSION_OR_CIPHER_MISMATCH problem for Sparc NAS (4.1.x firmware)
This workaround eliminates the redirection of http://nas-name-or-ip/admin to https://nas-name-or-ip/admin for NAS running 4.1.x firmware. It does require ssh to install.
Entering https://nas-na...
Jan 21, 2023Guru - Experienced User
givememynamebak wrote:
I think with any version of Firefox (I'm using latest to date 109.0 on a Mac) you can go to about:config and search for security.tls.version.min and change it to 1. Then you can get to FrontView on older ReadyNAS without needing specific versions of Firefox.
That certainly is simpler than downloading an old version. Thx for sharing.
givememynamebak
Feb 14, 2023Luminary
StephenB- FWIW: Also in Firefox, you can also change security.tls.hello_downgrade_check to false to get rid of the TLS Security Warning where you have to click accept to proceed. I use Firefox on my home network and Chrome for everything else.
Also in windows 11, you can search for "Turn windows feature on or off" and check "SMB 1.0/CIFS File Sharing Support" to discover the network shares.
Thankfully they leave these as options for us!
