Feb 18, 2022Guru - Experienced User
Workaround for ERR_SSL_VERSION_OR_CIPHER_MISMATCH problem for Sparc NAS (4.1.x firmware)
This workaround eliminates the redirection of http://nas-name-or-ip/admin to https://nas-name-or-ip/admin for NAS running 4.1.x firmware. It does require ssh to install.
Entering https://nas-na...
Mar 11, 2023Guru - Experienced User
SamirD wrote:
I remember when researching this upgrade for my ultra 6 that 4GB would make it run a better than 2GB.
If your system has two RAM slots, then 2x2GB is a good option. Though many OS 6 NAS run reasonably with 2 GB.
Sandshark
Mar 11, 2023Sensei
It's not dual channel RAM, so 4GB just gives you more, not a parallel path, and the speed improvement of 4GB vs. 2GB is minimal. But that kind of RAM is dirt cheap these days, so you might as well go for 4GB.
