Feb 18, 2022Guru - Experienced User
Workaround for ERR_SSL_VERSION_OR_CIPHER_MISMATCH problem for Sparc NAS (4.1.x firmware)
This workaround eliminates the redirection of http://nas-name-or-ip/admin to https://nas-name-or-ip/admin for NAS running 4.1.x firmware. It does require ssh to install.
Entering https://nas-na...
SamirD
Mar 13, 2023Prodigy
Yep, moving to 4GB on the ultra 6 is truly dirt cheap and a nice bang for the buck even on OS4.
Sandshark
Mar 13, 2023Sensei
4GB modules that work are not usually dirt cheap. The cheap ones are typically 2Rx4 (often labeled "AMD only" or "High Density") and you need 1Rx8. That's why we are recommending two 2GB modules.
- SamirDMar 13, 2023Prodigy
Yep, but they're nearing the end of the bathtub curve so they will also become relatively cheap again too. I was lucky enough to buy a lot of DDR2 and found a set of crucials that were on one of the lists posted here of verified modules. Just haven't had time to install them yet.
