Feb 18, 2022Guru - Experienced User
Workaround for ERR_SSL_VERSION_OR_CIPHER_MISMATCH problem for Sparc NAS (4.1.x firmware)
This workaround eliminates the redirection of http://nas-name-or-ip/admin to https://nas-name-or-ip/admin for NAS running 4.1.x firmware. It does require ssh to install.
Entering https://nas-na...
Bubba_Smitty
Dec 29, 2023Initiate
"There is also an add-on for 4.2.31 (which is now working) here: https://rnxtras.com/
Hello world,
First ever post so forgive me if I stuff up here and I understand this is a very old post, however I hope you see this.
The above link you quoted unfortunately is no longer active.
Although your instructions for using SSH are great, I am fairly new to NAS stuff and I am hesitant in trying it, as I don't want to brick the NAS I inherited.
To elaborate, I inherited an old ReadyNAS NVX business edition with 4 disk bays. I have managed to start using it and installed the last ever firmware update 4.2.31 available for this 32 bit model NAS. I have done some research and believe there are no further firmware updates for this particular 32 bit NAS. I have no idea what cpu it's using or memorey onboard or any other details.
I am using RAIDar to access the frontview via Firefox Browser V121.0 (64-bit)
So like the last member you were assisting, All I would like to do is update the TLS version on the NVX to 1.2 so I don't get that pesky message from Firefox and Chrome etc. Plus I imagine it will make it more secure to connect to the NAS. I only use it on my private network and have no intention of accessing it over the internet.
So after all that.
Is there another place I could download the add on that would update my NAS to TLS 1.2? Is there a way to find what CPU it uses for addon compatibility?
Any assistance will be greatly appreciated.
Thank You.
Dec 29, 2023Guru - Experienced User
Here's a direct link:
Correct. It cannot be converted to OS-6, and 4.2.31 was the final firmware. If you attempt to convert it to OS-6, you will likely brick it.
I don't recommend port forwarding to the NAS even with TLS 1.2, as the firmware hasn't gotten any security patches since 2017. If you have a router that includes OpenVPN, then you could use that to get remote access. Netgear Nighthawk and Orbi routers both have OpenVPN.
- Bubba_SmittyDec 29, 2023Initiate
Thank you so much for your prompt response and the link to the addon it worked a treat after reboot.
I'll only be using the NAS as storage mostly, so I have no need for access over the internet, just local network.
One day I'll probably purchase a new NAS with updated protocols but for now this should suffice.
Again thank you very much for your assistance. 🙂
- StephenBDec 30, 2023Guru - Experienced User
I'm glad I could help.
