Feb 18, 2022Guru - Experienced User
Workaround for ERR_SSL_VERSION_OR_CIPHER_MISMATCH problem for Sparc NAS (4.1.x firmware)
This workaround eliminates the redirection of http://nas-name-or-ip/admin to https://nas-name-or-ip/admin for NAS running 4.1.x firmware. It does require ssh to install.
Entering https://nas-na...
Weaverita
Feb 22, 2024Apprentice
StephenB Thanks.
I have heard you explain this before, but it finally landed. Yes, the branding / model / versioning really took me off the rails. Lesson learned for anyone in marketing.
I have a ReadyNAS314 and Ready316 that are still working for me so I think it is time to say goodbye to the NV+V1(NOT V3). I can not expose this old unit. Too risky.
A very gracious thank you again Stephen for all of your many contributions. You rock.
PS. I do need another NAS unit. Any pointers to a good discussion forum for new brands / models to buy? Netgear? Synology? Buffalo? Qnap?
Feb 22, 2024Guru - Experienced User
If I were looking now, I'd start with
- Asustor
- QNAP
- Synology
(alphabetical, no priority). This is just a starting point, as I don't own any of these.
Since I have an always-on PC acting as an application server, I'd also be looking at USB-C (or PCiE interface) expansion chassis to connect directly to that PC. Then I could create shares on the PC. Not sure I really need RAID, given the size of current disks and my backups.
