Feb 18, 2022Guru - Experienced User
Workaround for ERR_SSL_VERSION_OR_CIPHER_MISMATCH problem for Sparc NAS (4.1.x firmware)
This workaround eliminates the redirection of http://nas-name-or-ip/admin to https://nas-name-or-ip/admin for NAS running 4.1.x firmware. It does require ssh to install.
Entering https://nas-na...
MacTheKnife1
Jul 25, 2024Tutor
This is a great workaround. Thank you.
I did not think i would be using the Readynas Duo in 2024 but I have 2, both have sat doing nothing for 10 years and I was about to bin them and in resetting them I fired them up again. Thank you so much.
SamirD
Jul 26, 2024Prodigy
You're welcome! Definitely do not bin them if they're still working! My NVX is still running strong and probably will for a long time. In another 10 years these units will be in demand as they will be the only type of units that will work with computers from the same era as modern units won't work. And I'm lucky enough that old computers work fine for what I need daily, so if you ever find yourself not needing them anymore, please reach out to me and I can give them a new home.
