Feb 18, 2022Guru - Experienced User
Workaround for ERR_SSL_VERSION_OR_CIPHER_MISMATCH problem for Sparc NAS (4.1.x firmware)
This workaround eliminates the redirection of http://nas-name-or-ip/admin to https://nas-name-or-ip/admin for NAS running 4.1.x firmware. It does require ssh to install.
Entering https://nas-na...
Request_Help
Oct 18, 2024Initiate
Hi, I came across this thread in searching for my error since plugging in my NAS for the first time since like 2021. I'm running the ReadyNAS Duo v2 on 5.3.13.
After reading though these responses, I downloaded the "Apache2_2.2.34-arm-0.0.1.bin" file from https://github.com/rdynsxtrs/r5bin/tree/master/apache2. I installed a very old verison of Firefox to get into the web interface for my device. I go to "Add-ons" tab and click new add-on. I select the BIN file but I get the error: "Invalid Update Image."
I then go to System->Settings-> and try under "Install Fireware." Same error. Any idea what I'm doing wrong?
Oct 19, 2024Guru - Experienced User
You aren't installing firmware, you are installing an add on. Look at the "Install Standalone Add-ons" section on page 77 here:
