Feb 18, 2022Guru - Experienced User
Workaround for ERR_SSL_VERSION_OR_CIPHER_MISMATCH problem for Sparc NAS (4.1.x firmware)
This workaround eliminates the redirection of http://nas-name-or-ip/admin to https://nas-name-or-ip/admin for NAS running 4.1.x firmware. It does require ssh to install.
Entering https://nas-na...
Oct 19, 2024Guru - Experienced User
Request_Help wrote:
I then go to System->Settings-> and try under "Install Fireware." Same error. Any idea what I'm doing wrong?
You aren't installing firmware, you are installing an add on. Look at the "Install Standalone Add-ons" section on page 77 here:
Request_Help
Oct 22, 2024Initiate
Hi, thank you for replying. As I shared in my post, following the steps for standalone add-ons also does not work:
"I installed a very old version of Firefox to get into the web interface for my device. I go to "Add-ons" tab and click new add-on. I select the BIN file but I get the error: "Invalid Update Image." "
