Feb 18, 2022Guru - Experienced User
Workaround for ERR_SSL_VERSION_OR_CIPHER_MISMATCH problem for Sparc NAS (4.1.x firmware)
This workaround eliminates the redirection of http://nas-name-or-ip/admin to https://nas-name-or-ip/admin for NAS running 4.1.x firmware. It does require ssh to install.
Entering https://nas-na...
Jan 04, 2025Guru - Experienced User
TokyoQuaSaR wrote:
I also had to add in "windows features" : "SMB 1.0/CIFS File Sharing Support" > "SMB 1.0/CIFS-Client" as explained here and now it finally works again.
Yes, that is also needed with Windows 10 and 11.
While you are at it, I suggest downloading the log zip file, and looking there for any errors (particularly disk errors).
If they use the NAS for primary storage, they also should have a backup plan in place. RAID isn't enough to keep data safe, and they are using a 12-14 year old NAS.
TokyoQuaSaR
Jan 04, 2025Aspirant
Thanks for the advice !
I actually checked the log and there are ATA errors from 1 of the 2 disks... Currently they kinda use it as a backup of their PCs and smartphones, at least sometimes they do, looks like they had not used it for a long time (the parents are not too young...). So I think it's fine to keep it like that. I set that up so that my wife receive an email when there is an error. I will probably change them the disk that is having errors soon though.
