jlahd
Jun 23, 2011Aspirant
X6-TL fails to boot
Hello, I have been using an X6-TL for some time. Now I ran into problems - the box won't boot. When I turn on the power, the power led first blinks quickly, then slowly, then starts pulsating. When...
jlahd
Hello,
it seems to be rev. B, as the memory is 200-pin SODIMM. And yes, the memory should be correct, it is PC2700 (256MB DDR 333MHz CL2.5). The original DIMM I replaced was PC3200 (256MB DDR 400MHz CL3).
