jlahd
Jun 23, 2011Aspirant
X6-TL fails to boot
Hello, I have been using an X6-TL for some time. Now I ran into problems - the box won't boot. When I turn on the power, the power led first blinks quickly, then slowly, then starts pulsating. When...
mdgm-ntgr
Jul 18, 2011NETGEAR Employee Retired
Was just wanting to know if you got to see it in RAIDar and saw e.g. an error message under the Info (far right) column.
If you power down and remove the disks (label order) and attempt to boot the NAS does it show in RAIDar? If so, what do you see under the Info (far right) column in RAIDar?
You might wish to connect your disks up to a SATA port on your PC and check them using vendor tools
