JSmallberries
Feb 18, 2021Aspirant
192.168.1.86 refused to connect
ReadyNAS Duo Windows 10 RAIDAR 6.5 Chrome won't access admin page: 192.168.1.86 refused to connect
Feb 18, 2021Guru - Experienced User
JSmallberries wrote:
ReadyNAS Duo
Windows 10
RAIDAR 6.5
Are you just seeing a security warning, or something more?
What is the status of the NAS? Disks ok?
Is this a new setup?
Did you try https://192.168.1.86/admin from your browser?
- JSmallberriesFeb 18, 2021AspirantThanks.
Old setup.
Raidar says both disks are healthy.
Putting that link in the browser generates the same error message from the browser. It more of a fail message than just a warning. It won't connect.- StephenBFeb 18, 2021Guru - Experienced User
Maybe try restarting it. To that gracefully you can hold down the power button until the LED flashes (which should take about 5 seconds).
See page 14 here: https://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf
- JSmallberriesFeb 18, 2021AspirantGood thought but no luck. Restart didn't work. I still get the same browser error.
