JSmallberries
Feb 17, 2021Aspirant
192.168.1.86 refused to connect
ReadyNAS Duo Windows 10 RAIDAR 6.5 Chrome won't access admin page: 192.168.1.86 refused to connect
Feb 18, 2021Guru - Experienced User
JSmallberries wrote:
ReadyNAS Duo
Windows 10
RAIDAR 6.5
Are you just seeing a security warning, or something more?
What is the status of the NAS? Disks ok?
Is this a new setup?
Did you try https://192.168.1.86/admin from your browser?
JSmallberries
Feb 18, 2021Aspirant
Thanks.
Old setup.
Raidar says both disks are healthy.
Putting that link in the browser generates the same error message from the browser. It more of a fail message than just a warning. It won't connect.
Old setup.
- StephenBFeb 18, 2021Guru - Experienced User
Maybe try restarting it. To that gracefully you can hold down the power button until the LED flashes (which should take about 5 seconds).
See page 14 here: https://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf
- JSmallberriesFeb 18, 2021AspirantGood thought but no luck. Restart didn't work. I still get the same browser error.
Do you still have access with windows file explorer (or finder)?
Is ssh enabled on the NAS?
